Twice these tiny little caps have become uncsrewed and disappeared on set. Grrr.
Any clue where to get just the caps and not buy another $70 connector or $200 cable????
Thanks!
Dave, we have had them fall off, but when we found them, and screwed them back on, they never remained screwed back on.. Seems like once they come off, the threads seem stripped as you can tighten them to the point where the resistance stops and the cap just spins. I would be interested in purchasing a couple of "new " caps and seing if that in fact solves the problem.. In the meantime, the cables work just fine without the cap, but Im sure the exposed wire under the cap should not be exposed, and for what these cables cost, the caps should not fall off ever
