Battery Repair
Must have missed this! Are there any specifics mentioned? Any links to read up on? I've been waiting for this
Missed this to, Anyone have more info ?
Nick, do these NONAME bats charge on AB chargers?
Pretty much no one is going to recell Lion batts. I believe there is a very expensive federal license required to do so because of the fire hazards, and as a result of that, very few if any battery shops purchased the license.
It drives me nuts that you have a $500-$1000 disposable battery that is only going to last a few hundred cycles. I have over twenty Anton Bauer batteries sitting on chargers that I never use anymore, because I have discovered cheap ($180-$200) no Name batts. They out perform any battery I have ever owned.
Nick
Guys, that post was 3 years ago. Since then RED has introduced RED Volts. Sorry to get you excited.
Just want to clear up some misinformation that has been posted here.........
Batteries are a consumable...... This means that they wear out/degrade and do not have an infinite life span, it is not
a manufacturer design just the chemical action happening inside the cells, expect 3 to 3.5 years as a standard life in some instances
somewhat longer but 5 years would be about the max for any battery to give better than 50 % capacity, this is going to be true use them or not.
All Pro Video batteries are fully reparable/ refillable/ and can be ReCelled, anyone who says otherwise is wrong!
The cost maybe prohibitive versus the cost of buying a new one but that is a consideration in each individual circumstance.
Having completed hundreds of Li-Ion packs from manufacturers such as Anton Bauer, IDX, SONY, RED, FREZZI, VARIZOOM, GENERICS, etc, etc.
and the countless NiCd & NiMh Packs. I can confirm this.
There are NO FEDERAL Licensing requirements for battery repair/ReCell!! Li-Ion or any other Chemistry.
Anton Bauer Chargers will only charge Anton Bauer Batteries (some exceptions in very early NiCd chargers).
The Anton Bauer 3 point stud mount is still the best available mounting system period! (I have not had a worn or loose pin issue yet, but have had many many V-Mount plate issues)
Regards John Ritter
www.ritterbattery.com
954-557-9765
Not sure why V-mount battery plates don't lock in much like Anton Bauer battery plates. You think they would.
thanks for sharing John
