owc just released a thunderbolt pci slot
Brian Merlen
40
Stamford CT
vestadalux.com
http://eshop.macsales.com/item/OWC/HELIOSTB1/
If I remember correctly the Red Rocket is a full length card and will not fit in it, correct? I am just looking around for portable rocket options to accompany my new laptop. I want to be a bit more mobile than using a xeon cart...
yea i was fairly sure it wouldn't fit, just needed to hear it from someone else! thanks!
PCI-SIG spec for PCIe cards states the maximum length of the card from the rear bracket to the front edge of the card is 312mm (12.283"). "Half-length" is defined as any card which fits within 167.65mm (6.6") or less. The Rocket is about 8" long... Won't fit in this OWC enclosure. It is about 3/8" too long to fit in the smaller Sonnet Echo Express. OTOH, that Sonnet enclosure is designed for "half-length" cards and actually gives nearly an entire inch of additional clearance over the official half-length measurement.
The sonnet is excellent.
I haave the two slot echo.
Rocket in one slot and a sas card in the other with up to 8 esata connections.
Makes offloads and transcoding on set a breeeeeze.
Just got my Helios, put it my Atto R680 and hooked it into my rMBP after installing the card driver. Showed up like a charm and interestingly enough it reads and writes at 725Mb/s to my MaxxDigital Evo 6G 8bay raid vs the 650Mb/s it achieved in the MacPro... I did have it installed in an x4 slot in the tower but this is a pleasant surprise I will say!
What is the recommended procedure for powering a raid on and off when using a raid card in a thunderbolt chassis? Should I still power off the computer before hand or would ejecting the raid then pulling the thunderbolt cable work....?
