It depends, but generally as near to the end of your workflow as possible, but BEFORE any compression/rescaling would be a good rule of thumb IMO.
doesn't matter when you do it les. run speed tests.
do make sure it's in the chain before blurs (including compression)... obviously.
My ?thinking? was that applying NR as the very first node would ensure that any processing is working on the image, not processing 'noise' - with unwanted effects.
I wish Resolve had OFX plug-in capability (I've got NeatVideo on OFX for Eyeon's Fusion, which has supported RED color/gamma 3 for since March) - as I don't want to apply NR as the last stage - and I really like Resolve's node workflow.
Yes, that was my assumption.I contacted Neat Video and this was their response:
Yes, our users often ask about the best place for noise
reduction in a chain of filters and usually I recommend to use
Neat Video in the beginning, before the noise is aggravated by
other post-processing that could make it more difficult to
reduce. Not that Neat Video would not work in the end of
dataflow, but using it in the beginning may produce somewhat
better results.
Also, specifically in AE, NV must go first in the stack of
effects, because of certain limitations of the host itself (they
are related to the temporal processing done by Neat Video and
support for such processing by the host application).
In Premiere, NV can work in any position.
Otherwise, the choice of using NV in AE or in Premiere depends
mostly on your workflow and preference.
Hope this helps,
The great part is with the "send to Speedgrade" function, you can bake all of this into a DPX if that is your workflow, so I would put my vote on Premiere.
To get the maximum grading flexibility and quality, you want to use R3D's, not DPX.
It's a real shortcoming of SpeedGrade and Resolve, that you can't use NeatVideo first and still use native R3D's.
If you want to use those programs, you might want to consider using R3D's, and then use NeatVideo on the rendered output.
I've seen quite good results using this method by https://vimeo.com/presynkt (who also has some great Resolve workflow tutorials on that Vimeo channel).
Certainly not ideal (he's outputting at 2K instead of 4K using the free version of Resolve, then using NeatVideo on the 2K, or at least he was a few months ago), but ... the results look very good and professional.
