Jon MIchael Puntervold
Hmm, it looks quite good! Do you rent out your set of Elites?
Here is a Elite 28mm 1.3 test I did a while ago. i will do some test not of boards later. Its a jpg still frame from Sony f3. Bad lighting just done in a hurry.
Roger
Hi!
Yes its quite good, besides when you put a lens this close to a test chart its almost impossible to have the whole plate in focus since the edges will be further away then the center.
I have owned a set of zeiss super speed, zeiss cp2, and two sets of canon k-35 lenses. Overall I am very happy with my Elites, both visually and mechanically. I even have a super rare Elite 100mm macro and also the Elite 25-80 zoom
Roger
Hi!
I will make a test wide open/ stopped down so you can see. I haven´t shot enough with them wide open and played with it in post. I usually shoot at 2.8 and above
Yes I think you are right about the digital being he same. I only know the 24mm has close focus 50cm on the digital and 25cm on the MkIII. I would guess the focus marking is a bit
different since the diameter is shorter. I like the 110mm since I can have matched lenses from 14mm-200mm. But I see the point of lighter lenses.
Roger
I
I Looooove the 25-80 zoom. I don't know what I'd do without it ;-)
The Illumina's did not fair well in any of these tests.
Matt, how did not the Iluminas did well in this tests?
Mind you, I never do this kind of tests, I only use Projectors, and real life situation with well controlled environment, lights included.
Hey Matt, as you know, i shoot almost everything exclusively with my gen 1 illuminas and i love them.. I have been shooting a lot of fashion and using the illuminas for the stills that are printed in the magazine as well. I have never had them tested because they produce beautiful images.. I would post stills from the magazines but i can not until the magazines hit the newsstands...
I think testing any set of lens before you buy them is a great idea.. In my case, I spoke with the Dp at length who was selling them, and Fred at FJS hooked me up with him, and I took a leap of faith in buying them sight unseen.. It was a great leap and im thrilled I bought them! And yes, I will be shooting the feature "The Ten O'Clock People" (based on Stephen King's story), directed by Tom Holland this fall. And of course, the camera will be RED Epic...
I wish Red would comment on this as they so want to be involve in the world of fashion photography...
Just curious if there's any optical difference between the Elite s35 and Elite s35 digital? I understand there is a weight difference and size difference but are the images identical? is one better than the other?
Thanks in advance!
