REd Epic file Probelms can any one help? Need some answers..
Andrew M P
Im having an issue wit my Epic M I have not seen before. I am getting a blue portion on the shot file and sometimes red... REFER TO PICTURES ATTACHED>> any one have any suggestions as to what might be causing this?
I ran into this issue once before. It was not frame-specific and only happened in one version of RCX Pro. When I installed a newer version of RCX Pro the footage transcoded without a hitch. Hopefully you're experiencing the same, since it's a relatively quick fix.
i saw the above one once in playback mode, but when looking back in redcine there was nothing
Ran into the same problem with an Epic-x. The artifacting was frame specific and showed up in Redcine and on camera. All clips on one mag were affected... luckily we haven't ran into the problem since. Would be nice to know what caused it though.
Have had this happen with a Scarlet, and had a board replaced, but I've seen it a few times. Same thing though shows on camera, and after export. However when playing through RCX-Pro there is no glitch.
