Doing some benchmark tests and need some 5K footage!
Ryland Jones
Los Angeles, CA
I am finishing up some benchmark tests with the RedRocket in Sonnet's Echo Express Pro doing transcodes from different configurations, SSD, eSATA, SATA, etc. I am in need of a 5K .r3d I can use that is at least 1:00 in length. preferably 6:1 compression. The footage will never be seen by anyone, I just need it for transcode tests. My current project is 2 Scarlet's, and we only have 4K at our disposal. Let me know if anyone can dropbox me a file. Thanks!
Ryland
where are you located
if its close enough ill give you as much footage as you desire at any res and compression you want
Luis
in LA area Ventura county area
I know, I just wanted everything to be 24fps. for the testing. But yeah, transcode would take the same time to render a 12 fps 2:00 clip as it would a 24 fps 1:00 clip. :-)
It shouldn't change the transcode time doing varispeed right?
That could work. Thanks!
If you want I got some 5k footage I can send your way.
only problem is it's 5:1, 5kFF, about 1:30 minutes.. and 7gb.. not sure how long it will take drop box to upload that. Will that work ?
