Mike McMillin
- Mar 27, 2012
- London
- www.mikemcmillinfilms.com
AMAZING!!!!!
snip PVC housings suffer much worse for fogging that Ali o
I'll echo Mike, here - how fares our fair cameras in confined space with hot little sensors? Does the water temp keep the system cool? Also, what batteries can squeeze into the housing, Gates and Aquavideo? Are we restricted to REDVolts or possibly AB Dionic 90? And finally... have you experienced or heard of condensation being an issue?
Thanks!
Chris ~
Temperature is fine, I spent 10 hours in a 31 C (nearly 90F) pool shooting a TVC and the camera was running the whole time, it never overheated once. I have the fans set manually to 100% on standby and 75% on record no problems at all. With regards to batteries I am using GMP 160's and I get two and half hours run time. I haven't had a issue with condensation but best practice is try and close the housing in an aircon environment or at least cool and dry. PVC housings suffer much worse for fogging that Ali ones. Plus I think having the fan on in the camera helps solve the problem also.
Hey, Jon.
You are absolutely correct with your observations
The physics of condensation is through water vapor cooling and compressing that produces liquid.
Plastic (PVC) housings conduct heat substantially less than metal, causing increased temperature and pressure inside the housing as compared to metal housings. For that reason, they are more prone to condensation.
Thermal conductivity of PVC is only 0.19. Glass is about 1.0. aluminium is massive 250 [W/(m.K)]
Aluminium will transfer the heat out of the housing much quicker than glass. But, in case of a PVC housing, it is the glass that would be much better heat conductor...and source of condensation at the same time.
Additionally, for strength reasons, PVC housings are much thicker than metal. This further inhibits the heat transfer.
Tensile strength of PVC is up to 60MPa. Aluminium alloys can go as high as 300Mpa. Titanium goes to about 1000Mpa.
There is, however, secondary reason of condensation inside plastic (PVC) housings. PVC has relatively high water absorption ratio. All organic polymeric materials will absorb moisture to some extent. Commonly PVC has water absorption in a range up to 0.4%. Metals have none. When PVC is warmed up, it releases additional water vapour inside the housing, which is then cooled by the glass port and can cause condensation more readily than a metal housing.
hope this helps
