Steve Sherrick
Right but this isn't the vault or the Digital Lab system. This is the Transfer Station for the Mac you are referring to correct?the virtual file system built into the codex server. you can set it to generate dailies as well married and baked with cdl. you just punch in the what you want in the codex server UI, and it can generate it on the virtual drive. but I always found it too slow for what producers want out of a day for on set dailies. not to mention i don't think it can do sync sound.
Zak, I suggest telling production they need to rent another tower on top of yours, and make sure everything is specced out right. with a second tower and another hand on deck you'll be fine. just transfer to a fast raid and than do the backups, and expect a decent amount of overtime.
it's not unmanageable, you just can't go in ill prepared. you could even do it with a laptop with a thunderbolt raid and pci expander. all it requires is the h680 connection.
make sure you're on the right drivers and firmware as well. and get a really good run through on codex operation. there are a handful of quirks you need to keep in the back of your head.
