I know that many praise using R3Ds throughout the process, but my own experience is that DPX log files can work fine provided they're made correctly and give the colorist all the range they need to make the pictures you need to see. DPX files are generally faster to work with, but a lot depends on your specific pipeline, computers, and software.
Lots and lots of available hard drive space on the post house's network is already a primary requirement for anybody working in 4K. Typically, the real issue is connection speed, interface, and other issues. The extra time needed to decode R3D on the fly and shuttle it back and forth puts higher demands on processors. DPX can be less overhead, and Apple Pro Res 422 HQ (or 444 HQ) even less still.But DPX are much heavier in GB than R3D, even 2k DPX. In either Color or Davinci, I allways worked from the R3D because this give me the best post-production solution.
But you can't even bring in R3d to COLOR....
