1st RED Wedding
Michael Pyon
NYC
Quite an amazing experience. I know that the audio can be a little better, but other than that, I want to share this video with the RED community and see if there are any questions, comments, or criticisms. I am shooting another wedding Monday, so really opinions are worth saying. Still learning and its a fun process.
https://vimeo.com/42935031
password: tisch
Michael Pyon
As you learn... get better audio! The words tell the story. Good pictures, they can get from stills.
Hey Michael, good job on pulling the RED out on a wedding. I'd like to try that too. I have a few questions:
- what kind of rig did you use to run around with the camera when it wasn't on a tripod?
- have you experienced any louder fan noise, say during the ceremony, or any other time?
- what lenses did you use, and did you find any particular lense to be the most useble?
- did you use any FF?
- is the audio, only from the Scarlet? - what mics?
- have you used wireless mic for the ceremony?
Thanks.
Thanks Patrik.
My friend had a slider that could be used as a shoulder rig. But we didn't have any follow focus or mattebox, it just made things lighter.
The fan is very very loud, and as you can hear, it was on a 100% the whole time because it was very hot outside.
Lenses I used are Canon L Lenses, the 50mm f/1.2 and the 24mm f/1.4.
We used audio from multiple H4n's.
I have used wireless mics before when i shot with DSLRs, and I have to say they work very nicely.
Cheers
try using a mix minus setting on ur field recorder(s).... think of it as HDrX for audio.... that way you can protect against too loud/soft sounds
I've been able to run mine in direct sunlight at only 40% fan without any problems. Just did that last weekend at an outdoor wedding. Before I did that though I have spent some time running the camera at only 40% fan for a good bit of time to make sure it wouldn't overheat or kick in full blast at the wrong time.
At first I was worried about the fan and the heat but now I find that isn't as big of a problem as the short battery life.
