Jamie Trent
- Aug 20, 2011
- Los Angeles
- www.jtladp.com
RED ONE MX CAMERA #5917 with only 23 hours
EBAY LINK FOR AUCTION
I have a good feeling this package will reach the reserved price pretty quickly. So any serious buyers, please call me before it gets up there because then it will be locked in.:smash:
Total of 23hrs as seen in photo. Camera was never ever rented and was purchased as a back up. Please excuse the lint in the photo's from the RED MX being wiped down.
We have another RED MX, which was used until it was upgraded with an EPIC.
This RED MX Camera is being sold because a second EPIC is on the way.
The MX Upgrade and CPU Board upgrade were $11,368.75 and the camera has only been used to run lighting tests and has been kept in mint condition.
Buyer pays for transferal of ownership through RED which will give you 90 days warranty for $750.00.
Package comes with 4 x PL Mount Prime Lenses. They are 1:2 lenses and are as follows. They should be cleaned & serviced which is ½ hr of time each.
The 35mm 1:2 PL mount has an Iris pin that needs replacing.
The 50mm 1:2 PL mount is in good working order.
The 75mm 1:2 PL mount is in good working order
The 200mm 2:8 PL mount is in good working order, needs clean.
You can purchase a 24mm PL mount lens for several hundred on Ebay and repair the 35mm which will give you a good set of PL mount Primes to begin shooting with straight away.
A Birger Mount and Impero is also part of the package as is.
Purchased with thoughts of using Canon L lenses which we had been told work great with the Birger mount.
It was not used as we were concerned about voiding the warranty if it was used. So the Birger and Impero are included as is with receipt showing from Birger test done. This was provided from previous owner. We bought it as a back up which again, didn’t see the light of day and sat in the box. So if you have EF lenses, they can be used straight away with this mount.
We have included a brand new Marshall HDMI 7” monitor with new Cine Arm as seen in the photo’s. New Marshall Monitor was excess stock and never worked on RED MX. Settings may need changing for it to work on RED MX. We included it as we don't use HDMI unless it is on our 5D set ups and this was another back up item. HDMI brand new and was tested on 5D and included as just a bonus monitor.
This is a great package which will enable you to get started straight away.
RED ONE MX is in excellent condition both inside and outside. A new MX is $25K plus tax which runs approx $27,350.00.
This package cost well over $50,000.00 and no doubt, the RED MX is an incredible deal to be able to buy right now at the prices they are selling for.
With so few hours on this camera, who ever gets this package is off to a great start.
We have set a low starting price and also a lower reserve price than other RED MX camera's previously listed in the past few weeks.
This camera with 23 hours is practically brand new and with the 90 day warranty with change of ownership, it is an incredible opportunity.
• 1 x RED ONE MX Camera Number 5917 with only 23 hours.
• 1 x RED NEW CPU I/O Board 12/01/2011
• 1 x RED 640GB Hard Disk Drive and Cable
• 2 x RED 8GB Flash Cards
• 2 x RED 16GB Flash Cards
• 2 x RED Brick V-Lock Battery, both have full charge
• 1 x RED Dual Battery Charger
• 1 x RED AC Power Supply
• 1 x RED DC Power Cable (10ft)
• 1 x RED LCD 5.6" and Cable
• 1 x RED LCD 5.6" Screen Protector
• 1 x RED 9" Arm
• 1 x MARSHALL HDMI LDC 7”
• 1 x HDMI Cable
• 1 x CINE 12” Arm
• 1 x RED Compact Flash Module
• 1 x RED Bottom Plate
• 1 x RED Top Handle
• 1 x RED Side Handle
• 1 x RED Top Rod Mount
• 1 x RED PRO New Top Front Rod Mount
• 1 x RED Cradle
• 1 x RED Cradle (Spare Back Up Cradle, missing 2 screws)
• 1 x RED Shoulder Dovetail
• 1 x RED 19mm Mount
• 2 x RED 19mm 18-inch Steel Rods
• 2 x RED 19mm 12-inch Steel Rods
• 1 x RED Mini XLR Cable w/ XLR Adapter
• 1 x RED mini-BNC to BNC adaptor
• 1 x 1650 Pelican Case
• 1 x RED Tools
• 1 x RED Wing nut backup pack
• 1 x RED Bolt Set backup
• 1 x RED PL Mount
• 1 x RED Birger Mount (Still in box, we never used it due to void warranty if used)
4 x Birger bolts
2 x Cables
1 x Plastic Sleeve
4 x AAA Batteries
2 x Antenna's
• 1 x IMPERO (Still in box, we never used it due to void warranty if used)
• 1 x 35mm PL Mount LOMO 1:2 Prime Lens (Needs new Iris pin = $180)
• 1 x 50mm PL Mount LOMO 1:2 Prime Lens in great working condition
• 1 x 75mm PL Mount LOMO 1:2 Prime Lens in great working condition
• 1 x 200mm PL Mount LOMO 2:8 Prime Lens (Works great & needs clean)
Package MSRP with upgrades, extra's and lenses $49,900.00 USD Asking $17,500.00 obo
Serial number # 5917
310-819-5023
• 1 x RED 9" Arm
• 1 x HDMI Cable
• 1 x CINE 12” Arm
• 1 x RED Cradle
• 1 x RED Tools
• 1 x RED PL Mount
4 x Birger bolts
2 x Cables
1 x Plastic Sleeve
4 x AAA Batteries
2 x Antenna's
310-819-5023
