FW update 3.0.7 stuck in progress
Akos Nyoszoli
Active member
Hello, I'm just updating to 3.0.7, and the progress bar has stopped for like 15 minutes now. It's at the "Upgrading Attached Peripherials" part, about 75%.
The camera is on AC power, plus a Redvolt for safety, so I can let it run for ages, but I'm a bit worried. Anyone had the same experience?
I didn't remove the side handle prior the update (I just followed the steps, and it wasn't in the instructions, like it was for the 3.0.0)
thanks for any info, I'll keep you updated, if progress starts
Akos
I had a Canon 24/1.4 on it, removed, but still nothing happened
(Still running, still stuck)
If it is getting stuck for longer than a minute or two no amount of time will fix it. You will need to power down and reboot the camera. Your cameras firmware has already been upgraded. Any peripherals that failed to upgrade will be upgraded on the next boot.
Aahh, thank you, Trent!
I let it run ever since, I didn't know what to do. Now it's all good. :)
