SINGLE SSD CASES
Justin Marx
Hollywood, FL
I could be the only one, but I find myself in many instances where I just need a single case to protect my SSD, weather on a boat, in the middle of the Everglades, in a car, or even on set when giving the full card to the DIT.
I don't want a neoprene pouch, or something that is big, just something simple and small like the ones for P2 cards.
-Safe from a little splash
-safe from pocket lint
-safe from a small drops
-easy to label and not get confused with the other 3 in the case.
-Clear case so you can see the roll number on the card
-small enough where you can take the foam out of your RED mag case and put 4 cases with cards inside.
How bout it? Anyone else?
Not what you're looking for but Lowepro Dublin 10 Camera Pouch is an almost perfect fit for a single card
Justin, they don't meet all the requirements you listed, but I've been pretty happy with Pelican 1010 cases for my SSDs. They have a soft plastic inner lining that holds the SSD very snugly. And they are extremely sturdy. They're a little thicker than what you're looking for, but they're only ten bucks apiece.
I guess no one needs them.. Hmm
To fit the cards with case in the already pre cut foam, these would have to be custom made and nobody made these yet.
and even then they would probably sit too tight in the pre cut slots or you might no be able get them in with case at all.
EDIT: sorry, misread your post about the foam.
I would love these too. Have a shell for each card. At the moment I'm keeping them in their bags to save them from the dust as much as possible.
No, I think we all need them at some point. For this use, I've adapted a little neoprene CF case from LowePro. I cut out the internal CF double sided CF sleeve, which made just the right amount of space to fit a SSD in snugly. Its perfect for me, fits in my pocket, light-weight, and does its job of keeping my card safe. It will only do moderate protection should a crushing blow hit the flat side of the case, but I'm really only using it when I need something small and mobile that fits in my pocket.
