- Thread starter
- #21
Shane - thanks for taking the time to give a detailed reply.The zacuto gear is heavy. Yes it will last forever but it is not really designed specifically for the epic or scarlet. I do own some zacuto gear dating back to the lexus 35 mm adapter days and do occasionally pull it out to solve a mounting problem but I think that it's overpriced and have to laugh every time that I see a full zacuto rig with dual handles and counterweights on the back. I'll put a battery on the back but no counterweights.
It seems that so many of the accessory manufacturers have never operated a camera for more than 5 minutes. Take a look at their rigs: how do you pull focus? Is the focus wheel jammed into your chin? Can you operate without looking 45 degrees up in the air? Is the lens above your head or is the monitor in your line of sight?
Not to date myself but the Aaton really was the perfect handheld camera, hell even the arri sr2 was a good second and there's a reason that the betacam form factor has persisted for so long. Look at these designs and look at the monstrosities that are being sold to unsuspecting buyers. Handheld work should be fluid and the camera should be a part of the operator, a crazy contraption on you shoulder will not achieve this.
Ok, rant over.
I like what wooden camera and innocinema are doing right now, they are obviously shooters. Look at their solutions.
Everything you say makes perfect sense about focusing, viewing the scene and balance.
But, due to my lack of experience with using a rig, I'm missing how Wooden can do this better than Zacuto? I hear what you are saying, and I'm looking at pictures of Zacuto rigs and Wooden rigs.
But, I must be mentally-challenged, as I'm having a hard time getting my head around the differences.
They both look similar to me, but the Zacuto seems to have a lower center of balance, at least if the Wooden 15 mm bridgeplate is used below the Easy Riser - as compared to the Zacuto Studio Baseplate.
The FF would seem to be out in front, where you can grab it, for both rigs. And both can use arms to move the LCD or EVF to the desired position.
Maybe it's just the weight? But, I see more pieces of metal going into the Wooden direction.
I know I"m asking a lot, but could you critique this video showing the Zacuto solution?
I'm just having a lot of trouble 'getting it' - but I respect the opinions of all the people who know a lot more than I do, so .... it's very frustrating that I can't see the big picture for some reason???
