Frank Cueto
- Feb 22, 2009
- Age
- 48
- San Juan, Puerto Rico
- www.reaktorpost.com
Jeff, how about some cinebench scores on the HPz820?
I did a custom configuration of the Z820 with the 2687W's and Liquid cooling and it was QUITE a bit more expensive than I was expecting. Not sure it's worth the extra money to be honest, even though it is very tempting. Just don't have the budget to go that route, unfortunately.I've had a Z820 in my possession here for about a day now. Overall I like it a lot. HP did alright with the PCIe slot arrangement, but I've encountered one issue I'm not too happy about -- the lowest PCIe X16 slot is perfect for accepting double-width cards as the adjacent slot (the bottom one) is a standard PCI 32bit legacy slot. Unfortunately, the Quadro 6000 (and also the GTX580 or similar) won't fit there because of all the other stuff running along the bottom of the motherboard. Seems like a real goof to me. Oh well... The GTX580 or 680 HydroCopper versions from EVGA would fit like a charm, but I would have to run an external reservoir and radiator as there's no way to incorporate it into the internal system without sacrificing a drive bay. I have all the bays filled and have even mounted my system drive, the SSD, in the gap above the top 5.25" drive bay. So that gives me the SSD, the Blu-Ray writer, and 6 x 2TB HDD's for workspace.![]()
I think I'll definitely still go with the 2687w's and just get a liquid cooler. Do you have any suggestions by chance? Never had to look into them, to be honest. That's pretty new ground for me. Would something like this (http://www.newegg.com/Product/Product.aspx?Item=N82E16835181017) work? I'd have to get one for each CPU, correct?2690's are a consideration, they seem to do just fine with air cooling. In the end, price will be similar. A good liquid system or, self-contained liquid coolers like what HP is using, come at a premium so that just about offsets the lower cost of the 2687W CPUs. Performance is going to be mostly similar, but the 2687's do score better in intensive tests and benchmarks.
That RAM doesn't look so bad in price actually. Seems I could go 128gb with those at only a few hundred dollars more.I have 64GB in both the HP system and the other SuperMicro based system I've put together. At least for the moment until my other RAM arrives (today). 64GB is a good amount. But for intense rendering where I can maximize all the cores/threads on this system, it's a bit tight. I would recommend the Samsung or Micron DIMMs if you can find them, it's a pain. I had a round-about way of getting them from Micron. There's these modules here by Kingston, which should also work just fine, but they're a bit slower at CAS-11. Which is what the HP system is using. They're HP-labeled, but I'm positive these are the same modules in my Z820. http://www.newegg.com/Product/Produc...82E16820239015
Looking forward to those 6000 vs. 580 tests. I also noticed this weekend that you can actually throw a 580 in the Mac Pro with 10.7.3 and it's plug 'n play. Do you have experience with that? Are there any caveats I should know about if I wanted to just splurge at the moment and get one to spice up my current Premiere system on my 2008 Mac Pro? I read there may be issues with the 6-pin this or that. Didn't do any extensive reading, but the possibility is intriquing.Only card I would potentially recommend over the 580 right now would be the Quadro 6000. It's going to be slower for some stuff, especially performance visuals and pushing textures around. On the other hand, even with 3GB you can bottleneck the card with that RAM amount if you're really loading it up with a lot of data. Overall it's better tuned and runs silky smooth in various 3D apps. I like it, but it's pricey. I'll be doing comparison testing between the Quadro 6000 and GTX580 in the HP system this weekend. I still have to get all my software installed though, I just finished installing all the HDDs a few minutes ago and out of time for today on that project.
I wouldn't say the SuperMicro is better. Only real difference is the PCI slot configuration and since you're assembling yourself, you can place it in as big of a case as you would like. The HP system is very quiet. Comparable to a Mac Pro, the only fan that I audibly hear ramp up under load so far is the one on the Quadro 6000.
The SuperMicro build on my end is noisier at the moment, but I can make it quieter by swapping out fans and whatnot. Not sure what else to say on that, it's as quiet as you can build it. If you want the quietest option, you will want to go liquid cooled.
Thank you very, very, very much Jeff,
I will go the HP route then.
Hmm. Interesting. I was looking at the Corsair H80. I'll have to dig a little deeper.As for the liquid cooling, I don't have any recommendations at the moment. I tried both the LGA-2011 compliant cooling blocks from CoolerMaster and ASETEK and neither one would fit properly over the CPUs (not big enough to fully cover) and the Cooler Master ones wouldn't properly mount to the sockets on the SuperMicro board. Kinda weird. I never got a response from ASETEK and CoolerMaster said they are working on a solution for the new Xeons. I'm using stock air coolers at the moment and they're working OK, but noisier than I would like and the CPUs run hotter on that build than on the HP.
Good to know. Think I'll just not worry about it at the moment. Thanks for the info.I'm looking forward to doing them here in the next couple days, just been having trouble getting to it. I'm not sure about the '08 Mac Pro with a GTX580... You're kinda reaching there and I see other bottlenecks holding you back. For starters, the RAM on the system is clocked at 800Mhz and it's already the bottleneck when working at 1080p and higher in Resolve on that platform. I would also be curious as to the power abilities in the older tower and if it really could drive a 580. It works alright in a 2009/2010 tower -- I addressed it in the Ne Mac Pro thread in this forum a little bit ago. In an '08 Mac Pro, I think I would go more for a GTX460 or even scrounge up an actual Mac Edition GTX285. It's still a great card and actually has pretty darn good CUDA performance. So does the Quadro 4000 Mac Edition. Of course the GTX580 is better if you can get it up and running, but like I said, I see other bottlenecks holding you back with the older system.
Hmm. I've priced my PC build at only $8k including the 128gb of RAM and the Dell monitor, but even with the 20% off I couldn't get the HP under $10k, and that was without a monitor. Although, honestly, the PC build doesn't really scare me at all. I enjoy the process of hunting down all the parts, and I've got a friend who builds servers regularly who is willing to do the actual build for me. Just hoping to make sure I get all the right components.My current SuperMicro based build and my HP are essentially identical in spec.. The HP worked out to about $1300 more, so yes there is a premium. All things considered, it's a small price to pay if you're short on time or don't want to chase down all the parts and test and all that, plus it has the 3 year on-site warranty included. Just be sure to use the coupon codes! Without them, you won't be able to afford buying their systems. lol
Mark, upgrading to 32GB would help, but probably not in a huge way. If you're careful about not holding too many apps open at the same time, you should be able to squeak by just fine with what you have. That would be an expensive RAM upgrade and money probably better spent elsewhere. Do you intend to hold onto the '08 Mac for much longer?
Just an FYI for those of you who have been following my posts regarding the dual Xeon E5 systems and HP Z820... The EVGA GTX580 Classified Ultra *WILL NOT* physically fit into the HP Z820. If I were to leave the PCI e bracket retainer loose and secure the cards with screws, then leave the PCIe airflow cover out of the mix, I can get the lid on the system. Not going to go that route.
Other than that, the GTX580 tests are looking good! GPU tests are progressing nicely and it looks like I may be sticking with dual GTX580 cards in my SuperMicro build and sticking with the Quadro 6000 in my Z820. I need a second card in the Z820 for additional CUDA acceleration. I'm torn between a lower clocked GTX580 (which will fit) or going with a Tesla C2075 which makes the HP into a "Maximus" configuration. Wish I had the Tesla here to benchmark with. I've heard it's pretty snappy, even though the specs on paper don't seem to show that.
Will have my final reports soon...
Mark, what is your current memory configuration now? The '08 Mac Pro has a dual-channel memory arrangement and juggling around memory modules or exchanging various modules could give you a significant speed increase. Going all the way to 32GB via 4GB modules of that kind doesn't make a whole lot of sense, IMO. It's going to run $950-$1100 to do it and the actual value of the '08 Mac Pro at this point is pretty low. Such is the way technological cookies crumble... Moving to 16GB via 8x2GB might be an OK compromise. You will get the fastest memory performance at least and generally speaking you shouldn't run out of RAM if you're conscious about which apps you have up and running. As for AE, it's a memory hog now that it's 64bit and if you're working with comps at 1080p and up with a lot of layers, you can eat up RAM pretty fast.
32GB is in a way a bit too much for the '08 Mac Pro or systems of that generation and prior. Sure, having it is great, but there are so many other performance restrictions and bottlenecks compared to newer hardware, it just seems questionable as to whether one should really dump more money into a 4 year old system.
Another option is to see if there's a used RAM kit out there you can pick up for cheap.
