3.2.8 Beta Bugs
Noel R.
North Bay, CA
Yesterday on a shoot the camera would not stop recording when the SSD was full. It happened to me twice, and I lost the last take. The only way out was a hard shutdown (Pushing and holding the side red button for more than 5 seconds). This didn't happen prior to the firmware upgrade (3.2.8) so I'm assuming that's what might of caused it. Would be good to know if anyone else is experiencing this same problem, or any others to help improve 3.2.8.
Funny happened to us Friday but on build 2.08 or something (rental body). Camera refuses to cut without hard shutdown. Then refuses to roll with new media inserted. Remove, reseat, reformat, no change. Upgraded to new release build, problem gone.
I had a strange bug that playback would be redlogfilm colorspace for all the clipa, really sure we were shooting rg3, and then i changed it in Playbackmode and then it was ok for all
clips, quite a strange bug also.
This happened to me as well. Build 3.2.8
Lost last take it seemed but played in rcx
Also, artifacts when punched in 1:1. Only once
Extremely noisy image after playback one time. Cycled power and it went away.
It's been mentioned on the other beta 3.2.8 thread as well...
If you have upgraded to 3.2.8 from 3.0.x without using the force_upgrade method, we recommend resetting the camera to it's factory defaults. This will ensure all settings are compatible with the 3.2.8 firmware.
