Hi All
I've just received my stage-3 package and overall I'm pretty happy with it. I've only had 1 day of testing so far and we run kind of a 'stress test' shooting high contrast, high detailed shots, multiple frame rates and resolutions - just to see where the strengths and weaknesses of the camera lie. We want to know what will pose a problem and what will be fine.
Shooting at 120fps in 5K looked good in some situations, but also produced some bad compression artifacts, especially in detailed shadows on a high contrast shot. I know this is being crammed into 12:1, and the area is obviously part of the underexposed portion of the image (as shadows would be), but the detail in them seems to cause a big problem for the compression engine. It's not sensor noise. The odd thing is when the camera is static the compression is worse, but when the camera tilts up and is moving, the compression seems to cope better. Almost like movement is easier for the compression engine to handle. Even when we scaled this down to 2K output it was so distracting it made the shot unusable IMO. Has anyone else experienced this?
Shooting 2K 300fps was a different story altogether, it was completely unusable in the same scenario above with a high contrast detailed shot. The blockies are way too much and virtually the whole shot looks like a low bitrate mpg. However, we took the camera indoors later and shot some slo-mo against a clean dark background. This time the compression engine didn't find this a problem and it looks pretty good for 2K.
I just wondered whether anyone was following specific guidelines or rules for shooting slo-mo in 5K and below? To me (and this is a first test only) results can vary dramatically from pretty stunning looking, to muddy and blocky depending on the amount of detail you throw into the shadows. A dark blank wall indoors looked fine on playback, but the tarmac outside brought out the nasties. Here's a couple of images from our test, one full 5K jpg where the shadows are full oF artifacts and a 2K in which the whole image looks poor. (the blockies are not from the jpeg compression.)
http://www.darklineonline.co.uk/uploads/2k300test.jpg
http://www.darklineonline.co.uk/uploads/5k120test.jpg
EDIT : just realised you can go up to 7:1 on 2K 300fps and we shot this at 12:1 (as we had just exited 5K slow mo). So will retest that particular shot with lower compression...
