Sound test
Sound Quality
Sound Quality
Don't if this is the same with Build 16 but it might still be of intrest.
http://www.sounddevices.com/notes/cameras/red-one/
Same in B16.
Sound Devices do make some fabulous audio recording gear.
And its not a surprise that separate sound will provide the optimal sound quality - but also note in conclusion they say :
"..the Red One’s ..audio performance is similar to many .... pro cameras we have tested.
This is perfectly acceptable for dialog, especially when hit with a good, clean line-level signal."
Stuart, does RED intend to make the microphone inputs usable?
I'm on build 16 and I tested my microphone, but to no avail...both phantom and with battery on my Sennheiser K6 shotgun.
I have used the on camera audio for a couple projects and its sound fine.
just dialog stuff, but fine none the less. I always have an audio guy with a mixer feeding line level and phantom off. No problems
I've fed the camera with a mixed Line signal and a direct mic (with separate phantom power box) and both performed very well IMHO. Having the 24bit headroom was very nice.
When I was experimenting with mike inputs I have seen only 3 bits of noise.
If the independent test shows almost 16 bits of dynamic range then it looks like we have 5 bits of headroom. This is a lot.
However do you know how many bits RED is sampling audio with?
16 or 24?
