Mixing Frame Rates on a Red Drive
tror53
Active member
www.omnikino.com
I couldn't find anything addressing the issues of mixing frame rates on one Red Drive. Does anyone know if this is an issues. We will be shooting 2k 2:1 with RC36 on Build 16.
As long as you are staying with the same project settings (aka, 23.98, 25, or 29.97) then you can mix framerates. It's when you change project settings that the camera won't let you record a different framerate in the new project if you've already got clips on the media.
Does that make sense? I set my project at 23.98 and then use Veri-speed to record all sorts of framerates.
Matthew
Thanks Matthew, yeah that makes sense. Everything seems to be working fine with it so far.
