R3D plugin for Photoshop-How?
David Callahan
Oklahoma City, OK
I have Photoshop CS5.1 and have run the installer, but it doesn't seem to be working. Photoshop CS6, I'm reading, will open it natively, so it doesn't need the plugin. What am I doing wrong?
The plugin will work with Photoshop CS4, 5, and 6. We detected an issue with the first release on Mac where if you have moved your Photoshop installation, it would get installed into the incorrect directory. The solution is to just manually drag the plugin into the correct directory. Do this by copying the plugin from /Library/Application Support/red/Photoshop Plugin/ into /Path/To/Photoshop/Plug-Ins/File Formats/ folder and it will appear next time you launch Photoshop. Is your installation in a nonstandard location?
David
I don't believe it is non-standard. What's the filename of the plugin? I'll do a search for it and move it if necessary. What's the proper installation location?
