Quicktime Export Missing Alchemy Effect
Alan Franks
I'm using build 13 of RCx for Mac, and the Quicktime export of my file isn't looking how it should. The image and curve settings I applied are present in the export, but it appears that the alchemy effect was not applied during export. Any ideas?
I haven't tried exporting the clip without alchemy, but if I disable alchemy within RCx, the clip looks identical to the quicktime export with alchemy enabled.
Hi Alan,
The Alchemy effect can be very subtle based upon your settings and output resolution. Can you over crank it just to see if it is applying at all?
Thanks,
David
