tomspark
I am trying to get my in camera audio sorted for a documentary. I have a Sound Devices Mix Pre D which is feeding audio to camera from a lav or boom mic via the mix pre d outputs set to mic level output. I have researched on the forums the best cable wiring and am using the appropriate cable wiring from the 3 pin XLR to 3.5mm mini-jack as described in this thread. (http://reduser.net/forum/showthread.php?71581-These-Cables-Work-(And-why))
The details:
I have set the input levels inside the epic at 24dB to align visually on the lcd display with the tone feed from the mixer. Audio records fine and is usable but certainly not without issue. In the interests of getting the cleanest possible signal, I can notice a low level hum/digital interference like sound which almost sounds like the digital version of film passing through a gate - it has a regular undulation to it. This sound is recorded to the r3d file because I can hear it on playback in red cine pro. I only get it however once the output of the mixer is plugged into the camera. I do get this sound whether the mixer is turned on or off with the cable connected between the 2. When the mixer output is not plugged into camera there is no hum. I only hear this when monitoring directly from the camera or using the headphone output on camera as a return to the mixer. This sound is not present on the mixer when monitored directly. I can hear this when the mixer input pot levels are dialled down to zero or the mixer is off. Its not too noticeable so its difficult to test with a mic plugged in without the mixer as I cannot turn the mic down. When I do turn the channel audio input down in camera to the minimum 8db, the sound is almost not there (can just hear it when audio output is turned right up. It is definitely introduced however once the mixer and camera are connected and dissappears when they are not. If I use the unbalanced mic out from the Mix pre-D instead of the balanced L and R outputs, (mini xlr to stereo 3.5mm mini jack into one input on red epic) it is actually a little louder.
Anyone else get this? Anyone know how to get rid of it?
Tom
The details:
Tom
