Ricardo Moreno
- Apr 17, 2008
- Los Angeles
- www.silverculture.net
I am selling this top cheese plate, use once. This is a very nice thing to have.
It designed to span the gap between the front and rear top rod mounts. It is compatible with both the 19mm top rod mounts from RED as well as the 15mm top rod mounts from Element and is must have for low-mode Steadicam operation.
The 1/4-20 holes utilize the same spacing as RED's top mounts. The 3/8-16 holes are on Arri spacing and run along the top and sides of the plate. CHEESE TOP PLATE It retails for $300. I will let it go for $250
