David Wilson
One very big difference between our Converter and the CineForm own R2CF tool is the way the color is interpreted:
While CineForm wants to keep everything "sensor flat" to provide maximum fidelity in further post, it thereby ignores simply all settings in the RED metadata, be it while recorded or from custom RMD files. So in the end most users are disappointed with the results, as they did not match what they have seen on-set or in RED CINE-X. While technically CineForms approach is OK, its not the best decision for the user experience in this particular case
Our Converter instead uses all the RED metadata information to process the final CineForm DPC, AVI and MOV files with exact those colors your expect. And clearly with full 12 bit CineForm depth, way enough to handle 16+ bit data in a log format, better than standart DPX files in most cases.
We will shortly provide demo versions of the Converter for interested people. You can mail me if you are interested.
Axel
Likely my own limitation but I've never been able to achieve the quality of color through Cineform tools that I see with Redcine-X. To have access to the CineForm codec and the sophistication of FirstLight 3D tools with the color from my RMD files sounds like the holy grail to me.
I would be very interested in working with the demo of your Converter when it is available. Axel, please check your PMs.
