Pasha Patriki
- Feb 14, 2009
- Toronto, Canada
- www.dop.ca
RED's cases for multiple SSD mags are great, but I find that in the field you should really have a separate case for each SSD mag.
There has been some posts about Pelican 1010 cases, but I found this one to work best:
http://www.bhphotovideo.com/c/produ...8/KBID/1150/kw/HP1300E/DFF/d10-v2-t1-xHP1300E
It fits the SSD really well, and is waterproof and crush resistant, and costs only $25!
It has mini pick-n-pluck foam inserts that are sort of useless because ther are neither too big or too small... However if you take our rubber insert, the case becomes JUST big enough to make your own custom foam insert which would fit the SSD nice and snug.
Cheers.
Cheers.
