Tim Fassnacht
- Sep 6, 2007
For all who are wondering exactly what you can and can't do with this new build...
from the Readme File included with Build 16:
Significant changes since Build 15.
* New .R3D file format - compatible with updated QuickTime Codec, RED ALERT.
* Digital Signal Processing optimization.
* Image Compression Optimization.
* Support for 4K 16:9 recordings in REDALERT and QuickTime based applications.
* Fixed high detail scene codec errors in 4K 16:9 recordings.
* Fixed polarity of audio recording relative to MIC and / or LINE inputs.
* Improved audio sample to video frame synchronization (lip sync accuracy).
* Reduced RED-LCD display tearing on last few lines in 4K record / playback.
* Addition of REDspace and RAW viewing modes.
* Updated file name structure to eliminate duplicate file names.
* Addition of Pre-Record (10 sec or 30 sec loop) mode.
* In-camera 1080p playback of REDCODE RAW 4K / 3K / 2K .R3D files.
* Improved display precision and color response of RED-EVF and RED-LCD.
* Addition of MONO mode Histogram.
* Improved accuracy of RGB Histogram display.
* Changed default Color Temp to be 5600K
* Seperation of Sensitivity (ASA) and Exposure (Compensation) parameters.
* Extended exposure times of up to 1/2 sec enabled in TIMELAPSE menu.
* Addition of Burst record mode in Timelapse menu.
* Added RED-EVF control over Audio, Shutter, ISO and Varispeed parameters.
* Changed COLOR exposure meter to reflect REDspace monitoring as default.
* Added programmable Tonal Response Curves menu.
* Support for P.C editing of file names of camera LOOK files.
* Addition of Exposure Check Strip to look around area of GUI.
* Look Around available on HD PREVIEW outputs when LCD and EVF are active.
* Improved video Genlock (Tri-Level Sync) lock for 23.98, 24.00, 25.00, 29.97.
* Added 1.85 and 2.40 Safe Action and Safe Title Protection Guides.
* Improved indiction of image magnify mode with new "X" cursor
* User programmability of A, B, C keys and USER 1, 2, 3, 4 keys
* Return to last menu position before exiting menus, when UNDO-SYSTEM is pressed
* Changed project FRAME RATE label to TIME BASE.
* Disabled auto-reset of reel counter on change of project time base.
* Added RESET # (manual reset of reel counter) in MEDIA menu.
* Changed FORCE REEL label to CHANGE # and relocated it to MEDIA menu.
* Decreased boot time.
* No roll-back of camera firmware permitted to Build 15 or earlier.
Known bugs with RED-ONE Beta Build 16 v3.1.2 firmware.
* First clip recorded after firmware upgrade may not display correctly - if so discard.
* LCD tearing may sometimes be visible in lower 10% of screen with 4K footage.
* Existing media reports "DISK INCOMPATIBLE" when mounted - reformat media to clear.
* Preliminary implementation of TONE menu (Tonal Response Curve) - expect updates.
* The Exposure Check Strip cannot be disabled - always visible when in record mode.
* In OPEN GATE mode, shutter SPEEDS 1/25, 1/30, 1/32, 1/33, 1/40, report inaccurately.
* In Timelapse, cannot use 1 sec SPEED in combination with INTERVAL of 1 sec.
* Video Genlock (Tri-Level Sync) lock for 50.00, 59.97 not yet verified.
* RED-EVF black gamma sets up incorrectly on power-up (SMPTE pluge not visible)
Operational restrictions of Build 16 series firmware.
* Image Magnify is not available during recording at 4K resolutions.
* Timecode output is not enabled on the LEMO 5 pin connector.
* Audio and Timecode are not embedded on HD-SDI outputs.
* 1080p HD-SDI outputs do not support PsF signal formatting option.
* HDMI output disaabled on playback when 1080p PLAYBACK mode is selected.
* COLOR exposure meter only operates accurately when in VIEW REDspace
* Limited GUI only available on HD Preview when both RED-EVF and RED-LCD are selected.
* EVF display with blank for approximately 3 seconds when in SYNC refresh mode:
- when exiting OPEN GATE mode
- after a change in Project Resolution
- after exiting MAGNIFY when in 4K resolution
- after a Varispeed frame rate change
* When in OPEN GATE mode, Genlock (Tri-Level Sync) is not available.
* Cannot exchange camera LOOK (.RLK) files with REDALERT! or REDCINE.
Copyright (c) 2008 RED Digital Cinema, All Rights Reserved.
