Arnold F.
What do I consider when choosing an aspect ratio? Why would I choose other than 16:9?
Maybe a dumb question, but I can't seem to find the answer anywhere... are we able to change aspect ratios in the current Scarlet build? I haven't been able to find this, except of course 4KHD
Cropping in post is super easy too.
Some stories just play better in other formats. For example; 2:1 might better serve a drama about a divorcing couple, who are emotionally miles apart, than 4:3.
If you have the option, ask yourself will one format better lend itself to a composition that is meaningful to your subject matter than another? But don't forget your personal comfort level. Can you make good use of the real estate? Can you compose comfortably in the chosen ratio? Sometimes it just doesn't feel right.
2:1 sounds good to me. If I understand correctly, it could be cropped down to 16:9? I could set my frame lines to 2:1 and just be aware that my headroom won't change? I could have this all wrong.
