Best Practices. Obtaining Proper Exposure. Share your methods please.
Thanks guys, and Noah. Your previous posts in this thread had some great insight to exposure, thanks for this input. I did some tests tonight and got some great results at 800 in gamma2 then RCX grading. Tomorrow I will try your suggestions and see what works. I did find that my digital meter(L758cine) looked better when metered for 320 on the meter and 800 on camera. Have to check into that still as well. Thanks again!
You can always just apply a redlogfilm look to your footage later in just a few seconds using RC-X.
I never heard of anyone SHOOTING in relogfilm. Who would do this and why? I've heard a lot about people using relogfilm in Redcine x.
I would say get it by turning down your iso, not depriving the sensor of light just so you can shoot ISO800 underexposed and not use the cleaner top end of the sensor's range.
"depriving the sensor of light"
So are you saying the histogram will contain the most information when the aperture is as open as possible? So even in well lit situations, you want to open the aperture as far as possible and use ND filters to open it a bit more?
Neither have I, but it seemed the user I was responding to was doing that. He did not really offer an explanation as to why, so I imagine it is possible it was just due to not fully understanding best best practices, which is exactly what this thread is for. On the other hand, I am strongly considering using Redlogfilm myself but with a corrective user curve (I plan to test this soon). Personally I noticed redlogfilm holds up a bit better as far as consistent dynamic range at all ISO modes, which does cause me to tend to lean toward it as a base for my footage. My concern with this is that without proper LUT support, the user curves that can be applied in camera (which only consist of 5 points) may not be powerful enough to de-log in camera, but I think it is worth a test to see if this is a good system for getting the most out of the system and seeing pleasing/accurate images while monitoring.
It depends on the scene, but generally assuming your camera is always capable of capturing 13stops (lets say) if your scene is contains only 9 stops, it is better data/image-wise to expose such that those 9 stops are sitting at the sensor's highest possible range (by opening aperture, shutter, removing ND etc) since then your scene is then represented using more bits in the 16bit container and more safe from being exposed to the noise level that increases toward the darker range of the camera. Potentially, in RED's 16bit linear REDCODE container, your 9stops would be represented in the value range of 128-65536 per photosite if you expose to the right by opening up as much as possible, whereas if you close down 4stops and use the lowest range of the sensor, it will be represented only with the values 8-4096 per photosite. One may look properly exposed at ISO 200 while the other looks properly exposed at ISO 3200. Of course this is a slight oversimplification in theoretical terms in an extreme range, and in practice it is not always useful to overexpose since you may need not have the lights or the stop or the control to know something hotter might not pop into frame during the shot that increases the range of your scene requiring more underexposure to avoid clipping. It doesn't usually make sense to shoot anything at ISO200 on MX and isnt really necessary since REDCODE gives you enough room that you dont really need to expose all the way to the right all the time.
But yeah generally, even in "well lit" situations, you'll get less noise and better use of REDCODE's bit depth by opening up and ISOing down but at the loss of highlight protection. It is a balance that is worth considering and understanding when you set your exposure. Then again if it really is "well lit" you'll be setting your exposure for your highlights and exposing to the right naturally anyway. The tradeoff is usually of greater significance as you work in lower lighting conditions or higher contrast situations.
Noah, are you using REDlogFilm or REDlog in Redcine x? REDcolor1 or REDcolor 2?
I haven't used REDlogfilm because of the milky look, but I have been hearing more and more that using it is the way to get the most out of your pictures. Do you know a good tutorial for using this method? Out of the box, usually REDgamma2 works great but I am happy to improve.
I'd stay away from the older curves (redlog/redgamma) since they do not seem to scale as well at various ISOs and may throw away some highlight detail. Older redgamma gets too clippy at higher ISOs and too muddy at lower ISOs, Redgamma2 seems to do much better in those situations.
REDlogfilm is great for people who like grading at least partly in log and it's great for getting the most out of your RAW for people using transcoding workflows. REDlogfilm also seems to me to hold dynamic range most evenly and reliably through all ISO settings but only by a little bit. It seems to me that for many people who don't like tweaking or don't fall into the first two categories of log grading or transcoding, redlogfilm may just complicate things and isnt necessarily something I'd recommend for everyone/everything because it takes a bit more work to make it look right in camera or in post.
Thanx 4 this thread. Thanx for the enlightment!
Thinking back, all the problems i encountered in post with my footage suddenly make sense.
One further Question:
If you have a shot that - by its nature - surpasses the dynamic Range of the Cam and
lets assume HDRx is no option because of fps-restrictions on the Scarlet and lets further
assume there is no option to fill teh shadows with a bounce or a lightsource. Would you rather
allow to clip highlights or allow noise to be present. I know this is also an artistic
decision but if this was a binary decision like lets say: Plague or Cholera ... what would you opt
for?
Would you rather
for?
For me it really depends on the case and the content. Probably more often I would expose for highlights given the chance and let subject go into silhouette if necessary since that can look very nice in its own way, but there are plenty of situations I would just let it blow out especially if having well exposed talent is of the greatest importance for the particular content.
I disagree. The concept of "native" ISO really doesn't mean much when it comes to most digital image sensors, especially RED's. Yes the color science for MX was designed with the ISO800 setting as a starting point, but that curve scales for other FLUT/ISO values quite well. The ISO800 rating is not nearly as useful as understanding the range of the sensor relative to that rating. By all means do use ISO800 on a light meter to get a sense of light levels and use it when doing carefully designed lighting setups while keeping the highlight and shadow range of the sensor relative to that rating in mind. But I think I would hardly recommend sticking to ISO800 as a camera setting as a rule at all.
My take is that for most for situations it is best to set exposure by the stop lights to avoid clipping but set ISO depending on desired "video levels". It is a waste of the the best/cleanest range of the sensor if you underexpose your sensor just because you feel tied to ISO800. For example in a particularly low key night interior, where the image you want has most of your redcolor/video histogram info far to the left, you could easily get a lot of noise if you leave your camera at ISO800 and light for that, whereas if you adjust your stop/ND/lights to increase your RAW exposure and then lower your ISO as far as possible while still keeping your practicals or speculars not clipping, you'll be using a much cleaner range of the sensor, because your raw histogram is exposed to the right and the ISO setting is adjusting your curve to place redcolor/video levels where you want them more toward the left of the histogram in this low key situation.
Why reinvent the wheel, this is a common practice in digital image aquisition, "expose to the right", and the software ISO/FLUT settings are great because you can expose RAW to the right and still use the ISO/FLUT to give you your look in camera and put your "video" levels right where you want them.
Probably the clearest explanation of an issue which is full of grey areas...
So...a question:
the actual native hardware ISO of the sensor is 320. Setting ISO higher doesn't add any noise from what I understand, since its just metadata and how much you are magnifying the values of all the pixels. Increasing ISO in low light just reveals the noise that is always there if the scene isn't lit enough. Shooting at 800 is a psychological way to light optimally for the sensor in most cases to give you the most stops of room up and down. Is this correct?
I'll second what Hutson just said.
The one bit I can note is the interesting aspect of adding HDRx into the mix is that you have a bit more flexibility in extreme situations. For instance if you have a hard shadow covering a building and a bright sky yet exposed for mid tones, flip on HDRx and over expose a bit to reveal more deep shadow detail and through your grade you have a lot of flexibility. Play around at 4 and 6 stops HDRx and you have a lot more room to play in those tough shots.
It's still on the plate that we might get HDRx at 4k on Scarlet X at 24fps.
25 fps please, please, please !!!
So the destilled Info out of this Thread is: Dial ISO320. Light and Expose to the Right of the Histogram but avoid Clipping. If dynamic Range of the Scene surpasses your Goal-Posts kick in HDRx and expose for the Main-Subject in the Scene even if clipping occurs. This Clipping will then be fixed by the X-Track Component of the HDRx in REDCINE. True?
It was stated repeatedly at REDucation that exposure should be judged at ISO 800 to provide the best highlight protection. It really doesn't add any noise. We compared identical ISO 320 and ISO 800 images at 4k. You mileage may vary.
Great thread. Thanks everyone. Except possibly Noah... :torsten_violent-smi
Just joking mate. Appreciate your depth of knowledge.
I personally found this short tutorial very useful and so thought some other new REDusers might aswell.
http://www.youtube.com/watch?v=pqTFBd84z54&feature=player_embedded
Best
Lliam
Ditto. Just did m first gig with the Scarlet and I now feel much better informed, as it answer the question I had in my mind all along. "If it's RAW, what difference does it make at what ISO I shoot?"
True. But why should i give away 1 Stop if I can protect the highlights all by myself? With Exposure Mode and the Histogram/Traffic Lights I can exactly judge if and which parts of the scene are clipping. So why use a built-in clipping safety that costs a Stop in the most precious Zone of the Histogram/DR?
Identical images meaning what? Just increasing ISO in camera yielding brighter video images but the same RAW exposure, or increasing ISO while reducing the amount of light reaching the sensor yielding similar video images but lower raw exposure?
I would say for the kind of stuff you are shooting, expose to the right as much as possible such that your highlights are not blown out, and then if your subject is too hot at ISO800, turn down your ISO until it looks the way you want. This will maximize the dynamic range of your camera for that scene and give you as clean blacks as you can get while still holding your highlights.
I'm not sture exactly what ISO 800 means from a histogram viewpoint?
Does ISO is set at 800 mean that the histogram is centered in the histogram screen as seen while shooting on the camera (i.e. bit range density/sensitivity is equal across the histogram ) ... right ?
[edit] ... found a thread that answered my question: http://www.reduser.net/forum/showthread.php?73602-histogram&highlight=histogram
Basically have display setting as "RAW" to show the histogram how I was expecting. If the histogram is changing based on ISO, then the RAW is not set.
My take away:
Video is more forgiving to the shadows than highlights - a crushed/noisy black is less noticeable than a blown-out highlight. So . . .
ISO800 is for those just getting started on RED as it offers more protection against user caused over exposure screw-ups
ISO320 is for those advanced users who fully understand (from experience) the sensor capabilities, and they are expert lighting designers so can read a scene and quickly fix the problem areas . . . pre-shoot.
ISO320 produces a "thicker negative" since it exposes the sensor at the maximum levels - at the risk of the highlights. Start with exposing/shooting at ISO800 - then lower to 320 as your skill and experience allows.
Oh and . . . buy fast F1.X glass
