Export audio only from Redcine X?
Are you suppose to get it out to wav or? I get it to .batch wich I guess is something that you could put in to a render que or something?
I just tried to make a new preset instead of trying to change the "unamed preset" i have in the list. Then I get rid of the batch option wich I could not change before. But my talent sounds like Chip and Dale so I better look for more settings in export.
I can change duration in premire and then it sounds about right. But I like to fix this in rcx pro.
Joel,
You were getting the *.batch file because when you setup/edited your export preset you had the "Generate REDLine Batch Script (No Export)" option enabled. This looks to be a bug. When you export with the BWF file format RCX should output it in the *.wav file format.
Thanks.
Armen
I have just been putting all clips with sound in the timeline and then exporting as BWF like David said above.
*Just a note, if you have have anything without sound, such as slowmo footage it will cause an error and stop the render queue (at least in the version of Redcine X that I have)
