Freaky Scarlet monitoring
Edward Blythe
Melbourne, Australia
Check out attached still. This has happened a few times - bottom and sides of the frame 'swap' so the bottom is at the top, the right is at the left etc. So that white wall on the left actually extends from the door jamb on the right. And the bottom of the bed is at the top of the frame.
It makes me punch my face.
Unplugging the LCD/EVF fixes it (happens in both). Anybody seen similar gremlins? Going to flash the firmware and pray for rain.
Also had an issue getting the HD-SDI output happening last night (first time I tried to get signal). Crazy monitor path. No want to send to Red. Want to work.
Mine does that sometimes getting out of 1:1 magnify. Annoying but does not effect the footage. So it's a little bug we have to deal with until the next build.
Yes experienced the same and sometimes a strong stuttering effect after black shading. Went after rebooting the cam or shutting down and unplug and plug the LCD cable, then powering up again.
I just go in and out of 1:1 magnify a couple of times usually to get out of it.
