Lens won't fit matte box
tadeo garcia
Chicago, Illinois
Hey all! Got a bit of a problem here, I just got a new 18-85mm zoom lens HOWEVER, my my matte box does not fit around the lens. Any help?
a thick black rubber band or other stretchable material around the lens can help you snug the lens up to the matte box and reduce light leaks.
Let the material stretch over the end of the lens to get a mm or 2 smaller diameter that may then fit inside the mattebox. Check the wide shot for any frame encroachment.
Which Mattebox are you using?
Scott thanks! But I think I did not word it correctly, what I meant to say is that the lens won't go into the matte box. It barely fits. It's as if I were to take a sand paper and gently sand the edges of the lens fitting on the box, it could actually fit. Jay, I have a redrock matte box. It's been REALLY great but this is the first time I've encountered something like this.
Curious what lens are you using?
No worries, a wide (and thick) rubber band stretched over the end of the lens will create a slightly smaller rubber diameter due the the rubberband stretching over the lip of the lens. its kind of a large and wide specialty rubberband but can be found at most office supply stores. Getting the right size rubber band is the key. it can be enough to allow the rubber to fit within the mattebox diameter and block light for those close cases. Not a perfect solution but quick and effective.
Scott thanks! Jay, I have a redrock matte box.
Red 18-85mm has 142mm OD while Redrock Micro has only 138mm Diameter Opening so it shouldn't fit. It may damage the front of your $9K lens.
I think you should look for a new mattebox.
By the way, I just got an OConnor O-Box and it has 150mm opening. Arri MB-14 or MB-28 will be fine for your lens.
Contact RedRock - they can probably send you a different lens connector. The version they sell in the Red One Bundle has a 142mm opening.
Here is a photo of O-Box and Cooke 18-100 Classic (150mm OD).
Mike, you are correct. They have 142mm opening for the Red Bundle so maybe they can just sell the part.
[FONT=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]Scott, Jay, & Mike, thank you guys SO MUCH!!!!! As a first time RED user it feels great to be a part of this community. I'll be sure to pass forward anything I learn along the way to new RED users![/FONT]
