19mm adapter on DSMC Modular Assault Plate?
Adam Michael Carr
Temecula, CA
Is it possible to put a universal 19mm mount on the Modular Assault Plate? I'm assuming you can since it has the 2 prongs in the front. If this is true, it would make the bolt on quick release rail compatible with all sizes of rails yes?
Even if the parts bolt together, you won't end up with standard vertical spacing using this approach.
