Looking for a Travel Safe replacement for Dust Off
mickpacifici
Culver City, CA
Does anyone have any ideas for a Travel Safe alternative to Dust off?
Something than can be refilled with a pump or compressor.
Ideas... anyone!
Thanks in advance
Mick
There was actually a CML discussion about this recently (unless that was you on there as well). I believe some people mentioned using small scuba tanks with a regulator as the best option. I personally have found a simple rocket blower (lenses) and anti static cloth (body) to be all I need for cleaning gear. Where are you travelling to?
I would suggest a small Nitro tank used in paintball play. There are paintball shops all over the place.
I suggest a manual option that is similar to the rubber bulb air blowers like the Rocket but with more force. The Hozan Z-263 has a valve that allows it to build up pressure and then release it with a fairly powerful "poof". No chemicals, no refills, no travel issues, etc. YMMV.
Cheers - #19
