David Battistella
- Apr 30, 2007
I am going to post a few step by steps to help anyone who wants to use FCP X and RED material while we wait for native support.
I test everything in real world scenarios. I am not talking out my ass.
Here is a basic FCP X workflow for starters.
SHOOT EPIC OR RED MX - EDIT AND FINISH IN FCP X
Brandon,
This is a "possible workflow".
Everything depends on where/how you want to edit, color grade etc. I'll stick to an all RCX workflow.
1. render out PR 4444 of your selects from RCX to a 4K File. You can use RCX in out point to trim etc. REDCOLOR 2, REDLOG FILM
2. Import the media into FCP X and have FCP "create optimized media"
3. Set your sequence like this.
4. Edit with the preferences like this...
5. Then when you are finished your edit/ color correction, etc you simply relink to all of the highrez files by changing the preferences. It seems to easy to be true but it is.
6. Set your sequence setting to the size of the orginal 4K media. Then just render the final sequence.
Now you have a 4K Prores 4444 rendered and color corrected sequence of your final edit. From here you can create all of your other "media" for uploading or whatever.
David
Brandon,
David
