v2.0.8 Beta Exposure warning!
Hey Antony, when you are shooting 24fps, the minimum shutter that you are able to set it 1/24. This has not changed. If you set your camera at lower fps, then you will be able to achieve slower shutter speeds.
You cannot exceed a 360 degree shutter angle.
OK, it looks like the camera still works as before.
It is just the Menu Map which comes with the documentation which is incorrrect.
Panic over.
Good to note. I'll see about clarifying that in the menu map.
Thanks Antony. :)
