Noah Yuan-Vogel
- Apr 25, 2007
- New York, NY
- www.noahyv.com
This thread is about finding an in-camera solution for magenta highlights.
PROBLEM:
So I keep seeing lots of footage from various RED cameras where white turns out very magenta, and it is clear from looking at R3Ds in REDCINE-X that this is because it is common for the green channel to have a lower video value than expected at clip level, presumably because it clips before any other channel. These magenta highlights are noticeable in at most ISO settings but most problematic and increasingly bad at ISOs below ISO800, presumably because as ISO decreases, fewer stops of highlight detail is stretched over the same range, increasing the contrast of highlights in that range. I understand this is fixed by the DRX option which is available in REDCINE-X but does not appear to be available for in-camera looks.
I am concerned that the over-saturated green photosites might also be affecting dynamic range somewhat.
SOLUTION?:
After inspecting several R3Ds containing clipped highlights, I found that generally for all images tested a tint value of ~27.5 would put green clip levels about where they should be relative to the red and blue channels and that this value tended to work to fix highlights at all ISO settings and in various other look modes.
So my question is, might it make sense to leave an optical magenta filter on camera at all times? If a magenta filter is available that equates to -27.5 tint, it should bring the green channel back down to where it should be relative to blue and red, possibly increasing dynamic range by preventing the green channel from clipping early. It would also allow us to correct those magenta highlights in camera and see the corrected images while monitoring and even record corrected images requiring less work in post. The camera would just always be left with the tint setting set to 27.5 (or G gain ~1.4) to correct out the magenta filter in images, but it could otherwise be relatively transparent.
FURTHER BACKGROUND:
From what I've seen, a surprising amount of footage shot on RED cameras gets out without this issue being fixed, so either people are not aware of it, not aware that it is easily fixable, or otherwise ignorant to any need to fix it. I've seen magenta highlights in the SCCE tests, Contagion, many finished shorts ive seen online recently and in the past, among others.
As I work with RED increasingly more frequently, I find I really want a solution to this since it is a significant issue in my mind and I would love to be able to clearly say to my clients that this is not an issue because there is are a number of very practical solutions for it that work very well. Id rather it not be an issue I have to be overly-vigilant about in post, trying to make sure whatever assistant editor or DIT or PA is handling or transcoding the footage makes sure to apply DRX to every shot, especially considering that it is never clear what R3D look options work in what editing or grading software. What if they apply DRX and grade the native R3Ds in some software that doesnt support that look option? Is that possible? Better to not have to worry about it.
I will test this when I have the opportunity and post results but as I have not had my Scarlet delivered yet I am not yet a RED owner myself so it is not so easy to test until I have a camera available to me.
Does anyone know if the tint values on RED cameras equate to particular Green/Magenta Color Compensation values?
Does anyone know what optical filter would be closest to the equivalent of -27.5 tint in a RED camera?
PROBLEM:
SOLUTION?:
FURTHER BACKGROUND:
