Joel Arvidsson
Does anybody have a good trick to minimize the green spike in flourescent light in camera?
Can you do that in camera? Sorry have not had so much time learning all menus just yet. Just found the tint menu on the manual. Thanks.
1) I suggest replacing tubes as a best option. Skin tones will be best this way
2) Add plus green to your cine lights and use a CC10M or CC20M filter in front of lens. It's best to take the green out BEFORE it hits the sensor at least part way.
3) Add minus green to flourescents.
#2 and 3 will usually suffice but result in poorer skin tones. Many will argue that skin tones can be graded back to normal but there is always a difference to my eye and you cannot manipulate them as subtly as you might like because you are doing a major correction to get them back to normal. This is all assuming you don't want warm green or cyan skin tones.
Try color correcting a RAW photo of someone under sodium vapor streetlights for a good illustration of the pitfalls of low CRI - or try grading out the effect of a strong party gel. This will be much less extreme than that, but it's the same idea. Plus, a spike is not a shift, if you fix the spike, then other areas will look more magenta than they should. A spike is a bit like a bump in a color curve, not like the whole curve staying straight but being shifted over.
