David Barlow
Has anyone had the following issue and, if so, do you know how to fix it.
I have two Epic cameras filming 3D on a very simple and completely manual rig so the cameras do not talk to the rig or any other external device other than a Denecke SBT sync generator. The cameras are genlocked and the shutters are working in perfect sync. However, the left and right eye timecodes do not match when shooting in varispeed mode. There is almost always an offset between the two cameras. At project speeds (24, 25, 29.97) there is no discrepancy but as the frame rate increases, the discrepancy gets worse . At 240 fps I can get 21 frames offset in the timecode. Apart from the trend to get worse as the speed increases, there is no fixed pattern. The degree of offset will vary from shot to shot. I am using head and tail slates with good old fashioned clapper so it is easy enough to resync the eyes in Redcine-X Pro (brilliant software by the way) but the editors are a bit concerned about keeping track of the left and right eyes once the slates get removed if they cannot rely on the timecode. Fair point.
The Denecke is put through a Kramer PT-102VN DA to split the genlock between the two cameras but the timecode output from the Denecke is split on a tee between the two cameras. I have understood this to be a reasonable way to do things but I am very happy to be corrected.
A final symptom. The monitor image is fine on the 3D monitor when the cameras are not recording. When in record or playback the eyes play out of sync on the monitors. I assume this is because the cameras rely on the timecode to synchronise playback and if it is off set everything goes out of sync. Usually the camera that I use to initiate the record (mostly the left eye) seems to run ahead of the other one but just to confuse matters this is not always the case. It is possible that I push the record on the other camera sometimes because I do put the rig in some fairly awkward positions and this would explain this. I am running v2.0.5 beta on both cameras.
Anyone got any suggestions? They would be most gratefully received.
David
David
