Adam Pitchie
Active member
- May 24, 2010
Hi Guys,
First post here! I have a bit of a technical question that I'm trying to figure out, and as of right now it's beyond my expertise. This is where you come in!
I'm looking to use a 3 scarlet setup for live events from time to time, and I'm thinking of using the TeraDek BOND to transmit video from 2-3 Scarlets depending on the shooting needs. There is a possibility that many venues will have Wi-Fi access, but can't always count on that.
My first question is if I'm transmitting 1080p video (in addition to recording to SSD) via HD-SDI, will I still be able to monitor video using either the bomb EVF or LCD monitor?
My second question, does anybody know the best way to setup audio to accompany the video for live broadcast with these devices? I'll be using two shotgun mics and a few lavs, and using lectrosonic transmitter/receivers to a sound devices 788T mixer.
Is there a better workaround / setup than this?
Much appreciated! Go RED!
-Adam
PERTAINING LINKS
Teradek Bond - http://www.teradek.com/bond.html
-Adam
PERTAINING LINKS
