Jonas Rejman
From what I understand about BSC, please careful, very non-scientific.
HOW SENSORS CAPTURE DATA...
The pixels on the sensor need a small amount of current, in order to function. When photons hit the sensor pixels, they create a charge in the pixel, per unit of time. This is the exposure. The amount of this current per time unit is then written as a digital value. In case of the 16bit EPIC it is 2 to the power of 16, so between 0 and 65 536 ...
If few photons hit the sensor, they create only a small charge, that is very close to the "pre-charge". The pre-charge might confuse the electronics, as how is it supposed to differentiate between the current that is leading into the pixel, and the one that the 3 photons generated when "someone" did something amazing and called it 4K timelapses ... :-D
This is where the BSC comes in. It measures the pre-charge value of each pixel. That's why the lenscap must be on, as it creates a matrix, on what the sensor sees (which is analogue noise) and what was in theory supposed to be black (that's why it is wise to put the lenscap on the camera AND put it into a dark place). Presumably, during recording, the BSC matrix is then subtracted from what the measured sensor values to arrive at the "ideal" theoretical "perfect black"...
There are 2 important values, that influence the quality of the BSC: exposure time and as we now see temperature.
EXPOSURE TIME...
With long exposure times, the pre-charge current is firing into the pixels. If you BSC at shutter 1/48 and then go to 1 sec exposure, the camera is expecting a pre-charge per pixel for only 1/48 of a second. This means, that if the BSC matrix is subtracted from the pixel, it is not sufficient over the length of the exposure to understand what might be happening to the individual pixel.
This is the reason why you get hot pixels when you do not BSC for long exposures.
It seems, that as on the photon level, at the given pixel size, all sorts of leak currents are raising up the digital noise, making it harder for the electronics to understand what is noise and what is the picture.
It also seems that some pixels react differently to different pre-charge current times.
Ergo, one has to BSC for a long exposure, because this measures how the pixel behaves over the length of the exposure during the shot later. -> the BSC matrix is equaling over the proper period of exposure, and if then subtracted from the frame, it bring back the perfect blacks.
TEMPERATURE ...
Now as we talk about those minute levels of current, we are on the pixel level in the analogue realm. Of course, temperature, that e.g. expands the sensor, and influences the conductivity of the conductors between the pixels has an impact on the BSC measurements.
If temperature X, the pixel pre-charge is y, and at temperature x+10C it is y+5, because the temperature raised the conductivity of the circuit by that amount, the BSC matrix cannot be accurate...
It is the exposure time, not the fps that determine the BSC. One can actually shoot at different fps, and keep the exposure time to have a dead-on BSC (for geeks only).
Ok, these are so small nuances, we are talking about, so to put it back into perspective:
BEST PRACTICES (disclaimer)
1. Perform BSC when camera on temperature, and on the temp of the shooting environment (approx. 30 mins preptime). Calculate this into your shooting shedule. Do it every day before shoot.
2. When going to less than 24fps, with longer exposure times, BSC IS necessary, to avoid artifacts.
For the nerds:
3. Try to avoid powering the cameras down, to avoid the sensor temperature to drop.
4. When going from 24fps to 300fps, it appears the BSC-recalibration is not need.
5. I would SUGGEST that everytime your exposure time doubles (from 1/48 upwards) from the previous with BSC, you need to re-calibrate.
6. Write down the sensor temperature at which you made the BSC.
7. If your environmental temperature changes, and you see the sensor temp differ more than 10 degrees C, consider a re-calibration.
8. If you are in a harsh environment, do not worry about the BSC too much
I am performing those tests on a glacier, with sun coming in and out, with cold winds and snow and temperature changes between 20C.
I perform BSC once camera is on temp once a day. I shoot at 800 ISO.
I sleep well.
:-D
EXPOSURE TIME...
TEMPERATURE ...
For the nerds:
I sleep well.
:-D
