Matthew Scott
"So shoot 12 fps on really grainy film (can you find super 8 any more?) , and you'll have something really "filmic."
Nah, that's cool, 24 clean is fine.
Okay cool, thanks for the 101 lesson, not to be rude but I'm pretty sure most of us know that. The point is, the closer we get to the look of real life with higher fre rates, the further we get from a "movie". And, personally, I dot like the lookof fluid silky smooth movies. Next some director will try and mainstream 96fps....and then 120fps.....
Just saying, to me, personally, I like what my brain does with 24fps.
Actually 1/36 second, so for 48 fps, that's 1/72. Correct?
Shutter Speed of 1/32 Second - 270° Shutter Angle for S3D @ 48 FPS
Humberto Rivera
Let’s start with a wide open shutter @ “360°” shutter angle, which is “1/24” of a second, shooting at 24 Fps with a 180° DEGREE SHUTTER ANGLE (1/48 SECOND), so a 270° shutter angle is between the two or 1/32 Second.
Humberto Rivera
Jeezus guys, it's not that difficult...it cant be 1/32, because THATS LONGER THAN 48FPS FRAME RATE COULD ALLOW
the shutters open for 3/4 of each frame, so 48/.75 = 64...it's 1/64th of a second exposure time
The 2D version of the show will just be dropping every second frame, but it STILL GIVES YOU 1/64th of a second exposure time, equivalent to a 135 degree shutter, so slightly less motion blur than you're used to but not really noticeable, as you can see from the first trailer.
I still have a lingering question because of what Peter Jackson said; “48 fps with a 270 degree shutter angle.” Isn’t a 270° (1/32) angle shutter, half of 135° degrees or 1/64 of a second. Maybe someone can please explain that for me, I’m a bit confused. Thank You!
Humberto Rivera
OK, let’s see if I have this right, he is shooting at 1/64 of a second, with a 270º degree angle shutter? Is that right? I’m just trying to understand. Thank You!
Humberto Rivera
One more question! Then the shutter angle of 270º is going to give him the same “Motion Blur” that you normally get from a 270º degree shutter, but at 1/64 of second? Does the “Motion Blur” come from the shutter angle or the shutter speed? I’m really trying to understand. Thank You!
Humberto Rivera
