dean tsolakis
- Jan 22, 2011
Hello REDS,
I'm about 2 weeks away from finalising my Scarlet deposit, when it just dawned on me naively i suppose,
The Scarlets limited motion capabilities of 4k@24fps means that it can't possibly cover the super35mm diameter??? So ALL current Cines primes and zooms designed for S35 are voided
at this resolution? ( unless i want to crop and minimise my angle of view ) is this True or have i led myself astray with confusing my research?????
I was looking at the RED One MX@ 4.5k 24.2mm x 12.5mm /s35mm equivalent ( 27.3 mm ) diameter the super 35 extracted area for 1.85.1 release
RED EPIC MX@5k 27.7mm x 14.6mm /s35mm equivalent ( 31.4 mm ) diameter Super 35 Full silent aperture
then the poor old Scarlet A native 5k sensor, that you can't capture motion at, not even at 4.5k :-(( Standard 16@2k stats. so Standard 35@4k i Suppose?????
Someone please tell me i'm wrong!!!!!!!! whats the use of using 4K when you can't use current lenses to cover it??? i don't won't to revert to using vintage Cine primes all the time
