Curran Giddens
- Jan 3, 2007
- Age
- 47
- Great Barrington, MA
- www.solarsystemstudio.com
I finally had time this morning to test out the new RED Modular Assault Plate. This plate is perfect if you want to go quickly from handheld with the Clutch to a tripod with a Quick Release Platform in a few seconds. Keep in mind this is only for 15mm LWS rod spacing.
There was a clearance issue with using the default Clutch configuration. To use 19mm rods on the Clutch you would normally attach the DSMC 19mm Universal Mount on the front of the QR and then bolt the Collarbone on top of that. But the Collarbone is too thick to allow the Modular Assault Plate to attach to the QR plate.
The good news is that the Clutch is infinitely configurable. And you won't be needing to use those 19mm rods, at least not with the required spacing to use a matte box, etc.. But I still like to use a short 19mm rod to attach the Chest plate.
Another option would be to use Rod to Rosette brackets instead of the Collarbone to attach the handles.
Here is the configuration I have settled on for now using the Dovetail Mounting Plate (Short) to attach the Collarbone. The bonus with this setup is you can take off the front handles just by sliding off the dovetail.
Rod to Rosette bracket for attaching the Chest Plate. And you can also use them to attach handles.
Final setup with a Red Brick Battery in the back to help balance the rig.
Quick release the camera from the Clutch and you are ready to go on the tripod in a few seconds.
