Canon Autofocus
Paul Russell said:
can you assign two focus points and switch between them using either the touchscreen or side handle, like a follow focus?
Rack focus is one of the options. You select your first focus point and press enter. Then select your second focus point and press enter. Then you half press the record button and it will focus on one. Press again and it will switch focus to the other. This only works on 1.7.9a and 1.7.10a at the moment.
I still can't make it work, i set up for the "double tap thing" but to no avail. i have 2.0.2 installed. maybe it only works with the previous ver. Its not a huge deal since I would'nt really rely on it but it could be the start of some cool tools, like setting two points in a memory and moving between then. any way if anybody figures out the focus thing I'd like to hear about it.
