Epic At 2K
Harry Clark
NYC
Hi guys,
I have had many people bring up issues with Epic at 2K (usually when shooting 300 fps) It's not the noise issue, it's the softness issue.
Below is a paste of an email I sent to my friend who is a very smart director/ editor down under. I wanted the smart folks here to comment, generally and specifically, on my theory.
Basically, I think the OLPF in the Epic is tweaked for the whole sensor/ 5K res (which is a good thing) but that 2K suffers too much when compared with the Red One.
Not a knock on Epic. LOVE IT.
Harry
Hey man. Hope you are well otherwise...
Without actually seeing the footage I can only speculate, but I have some beliefs about 2K cropping in general and Epic specifically. Take them for what they are; information from a hack corporate video DP ;)
First of all, 2K is soft. there is no way around this. When you shoot any cropped resolution with Red or Epic, the apparent sharpness goes down. 3K is pretty acceptable in my experience; 2K is SO different looking that I generally recommend skinnying the shutter a lot and even hardening the lighting somewhat (you're only really resorting to 2K for high speed so the shot will have a somewhat specialized look anyway) The Bayer pattern on the sensor requires a certain amount of oversampling (remember, it's really "inventing" some color resolution in post when you process the raw data) 2K is 2048, really just a bit more than your final resolution of 1920.
Secondly, 35mm glass (counterintuitively) is "lazier" in its resolution that 16mm in general. Without belaboring the arcane theories behind how they design lenses, generally the smaller the frame the sharper the glass needs to be to resolve the same number of line pairs per millimeter. If you take a 25mm lens that's designed for 35mm film cameras, and a 25mm lens that's designed for Super-16, and film a test chart in Super-16, the lens designed for Super-16 will resolve better (it won't fully cover the 35mm frame so you can't benefit by using the sharper lens in 35mm) The rehoused Hassleblad medium format lenses that they use in the Clairmont "Swing And Tilt" and the Arri "Shift And Tilt" lens systems are incredibly soft in 35mm, even more so in Digital 35 formats. All lens designs are a tradeoff in one way or another, but this is a well-known issue. I think it is likely the smallest factor in play in your situation.
Third, the other factor that comes into play (an the factor that I think is most important in this particular situation) is the Optical Low Pass Filter. All digital motion picture cameras feature an OLPF (often it incorporates some sort of IR and/ or UV in the glass) glued directly onto the sensor. It has a secondary feature of protecting the actual sensor surface and keeping contamination off it. Its primary feature is to tweak the image. An OLPF is just a piece of glass with some sort of diffusing pattern on it, usually a "lenslet" or dot pattern, like a Soft FX or Classic Soft filter. Its job is to actually LOWER the incoming image's resolution before it hits the sensor, specifically areas of high frequency or high detail; hence, it's called "Low Pass" because it passes only low-frequency details (You could perhaps call it a "High Block" filter) Without this filter, most images would feature HORRIBLE moire patterns, chroma artifacting and other pattern noise (think 5D moire issues times ten) All manufacturers have their own philosophy, their "secret sauce", when it comes to how much detail to knock off, but all cameras have them. Red cameras are optimized for the use of the entire sensor area, and the OLPF does a nice balancing act of producing an image that has enough resolution for a large theater screen and enough smoothness for an HDTV. Ideally, if you were shooting a cropped area of the sensor, you would have a much lighter OLPF in place. It's not really possible with current sensor block designs to permit a swappable OLPF, so you are stuck with the one that is optimized for the way we shoot 95% of the time.
Lastly, Epic at 300 fps, specifically. I have no insider knowledge and am not accusing Red of anything nefarious. But I think they changed the OLPF design for the Epic. I think they fine-tuned it to accommodate an sensor area that is somewhat larger and higher resolution that the Red MX (even though the sensor is the same, when installed in a Red One it's cropped to be 4K) I think they made it the best compromise they could for 5K, but in the process made it worse for 2K. My own tests with 300 fps at 2K parallel what you are saying. They look much softer than a 2K image from a Red One.
Not sure what the way around this is, my friend. The use of a 16mm lens, harder lighting, more f-stop, and skinny shutter will all help. Last resort, there are other options for 300 fps (Phantom and Weisscam) Cameras designed specifically for high speed photography are really, really good at that application (and really really lousy at 24 fps traditional shooting; I got stuck using a Phantom to do an interview two weeks ago- arrrrggghhh)
Of course I would always rather use my Epic for everything all the time ;)
Harry
On Nov 19, 2011, at 12:04 AM, XXXXXXXXXXXXXXX wrote:
Hi Harry, hope things are well. I have a Red Epic M question and thought you might know. I'm shooting a commercial on the Epic and I did some tests, but they look terrible. I'm shooting at 2k 300fps, T4 on a zeiss ultra prime and Red Prime - both look incredibly soft. I know it's not the lenses, can't seem to figure out what we're doing wrong with the camera. When we shoot at 25fps 5k - it looks fine in an HD sequence, but only at 25% (filling the frame), if i set it to 100% the image looks soft and has a shitty glow around the edges. I tried in after effects and it was the same.
I've searched Reduser but found nothing too helpful. Any ideas?
XXXXXXXXXXXXXXXXX
EPIC (and Scarlet) is soft at 2K and you can get many consumer cameras under 1k$ that are sharper and more detailed at 1080p. At 5K EPIC is really sharp.
All these resolutions with cameras don't really mean anything. What matters is the quality of the pixels, not the quantity. If you made 5K using GH2's or 500$ Sonys pocket camera pixels it would be twice as sharp and detailed as EPIC.
Check this: http://reduser.net/forum/showthread.php?64983-RED-Epic-verus-Panasonic-GH2
All due respect to Josh, but the real issue here is quantity of pixels.
In the current Epic build, 2K is only enabled at 2.4 to 1. The frame size for that raw image is 2048 x 853. 853 is barely enough pixels to resolve 1440 x 720 (720p) after debayering. You really have to get beyond 1250 pixels high before you get enough pixels to truly resolve 1080p. So for any full HD use, 2K is going to be a blow-up. Add to that the fact that the image is completely unsharpened coming out of RCX or any of the SDK implementations (AE, Premiere, etc) and it is a very soft image. Sharpening will help. But the real answer is for the 2K 16 x 9 and 3K frame sizes to make their way into the firmware.
When it comes to over sharpened 1080p video, a lot of people misinterpret aliasing and false detail artifacts as sharpness. Gh2 is not particularly good in this respect. It looks superficially sharp but lacks true detail. Shoot a GH2 at its 2:1 crop mode and see how it compares to a Red at 2k. 16mm sized format on both cameras.
Red is optimized for a smooth film like texture to its images, not the over sharpened false detail of video. The OLPF has to be optimized for the pixel size of the sensor to reduce aliasing and eliminate moire. This does reduce apparent resolution.
Red 2k also looks better to me when shot with S16mm film lenses, the MTF is more optimized for the smaller image area.
I believe the Epic OLPF is actually designed to be user removable/replaceable. Red showed an optional ND OLPF at NAB, but from Jim's recent comments they are changing the design of the whole thing based on the flare issues that people have been having. He says a new solution is coming very soon. So, at that point, when it is clear that it won't void one's warranty, all someone needs to do is remove the OLPF and shoot some tests at 2K. Perhaps if that turns out to be the reason for the softness, there can be a 2K specific OLPF to improve the image quality in those formats.
Gosh, I really can't wait until you get banned from here.
Huh? Because reality has no place in your day dreams? Should I lie and say that 2K on EPIC is sharper and more detailed than any consumer 1080p camera? Would you be happy then?
Here is second opinion from Bloom:
To get the rather yummy 120FPS we are talking a lower than even 720p resolution of 1k. Not great. This will change as the quality is improving, but currently the 2k on my Epic is rather ugly. Very blocky looking noise. I wonder what the quality of the 1k will be.
http://philipbloom.net/2011/11/20/scarlet/
You might want to inform him that you would like to get him banned too.
Let me give some Hard hitting truth here myself - the "2k" 2.40:1 aspect ratio on epic isn't really 2k. Its actually more like 2048 x 854.
Since a lot of the time we are measuring by the vertical resolution (as well as horizontal) this would be the equivalent of somewhere in between 720p and 1080p.
Specifically 134 pixels more than 720p, and 226 pixels less than 1080p.
So in all fairness - yes it doesn't resolve quite to the level of 1080p in widescreen mode.
Another big thing that we have to look out for is our methodology of Rendering.
I would NOT recommend rendering a 2048x854 file out to 1080 using redcine X. It doesn't have the best uprezzing method.
I'd try to debayer to a 2048x854 for 2KWS from redcine X, and then either letterbox it into a 1080p space, or upres using a superior scaling method.
I think you will all be much happier with that debayering and scaling method.
Alpha 2.02 firmware has a new 2k mode - I'm guessing its more like 2048x1080. I'll check it out when I have the chance.
Here is second opinion from Bloom, you might want him to get banned too:
No - I'd like to not hear you come on here acting like you know things, when you've never even used an Epic for one day in your life - or please correct me if I'm wrong.
Then you cite other people's statements as hard facts without evaluating for yourself with your own firsthand experience:
SCCE (Single Chip Camera Evaluation) for instance
Or
an article from Philip Bloom.
Now, Rather than Slag Philip Bloom (the easy way out) I will say that YOU, my friend should be doing your own research, and then posting here.
I see all kinds of statements from you like you are an expert, and yet you have yet to produce any scientific tests, or even beneficial community discussion here of your own.
Best wishes, and please - the hyperbole is so thick here it gets boring sometimes.
I shot some 150fps @3K 8:1 today with the new firmware - looks very sharp. Twixtor up from there for now until there is a better 2K solution
Also - let me ask WTF this quote even means:
"To get the rather yummy 120FPS we are talking a lower than even 720p resolution of 1k. Not great. This will change as the quality is improving, but currently the 2k on my Epic is rather ugly. Very blocky looking noise. I wonder what the quality of the 1k will be."
The first thing I shot on Epic - ever was at 5k at 120fps. No decreased resolution necessary. Maybe he means 300 "Tasty" FPS?
For that - I'd like to point you at one of the first EVER Commercial Productions (to my knowledge) shot at 300fps using the Epic Camera.
For this Adidas Spot - If I remember right the 300fps capability was released on a Thursday or Friday. We shot this commercial Monday. They were going to Rent a Phantom. I told Them - go Epic at 300fps. You won't be disappointed.
They Weren't disappointed.
http://www.youtube.com/watch?v=cjuhsGW3CS8
http://www.youtube.com/watch?v=6wVZ6jhjVy4
Or
So now you are just upset because what I said was true. Ok...
I haven't used EPIC yet and it wouldn't matter if I had because test or comparisons don't have any value and you have to make your own tests to see the real results (I was told this few times). There's no way you can prove anything here.
One more thing for you Josh Snyder - If you are looking for a very high Resolving 1080p camera, I would recommend ordering the Panasonic GH2 from B and H with 14-42 kit lens for $795. Then apply the Driftwood GOP1 hack using Vitaliy K's Ptool utility. Then make some detailed high resolution films and get back to us. You will have to use Twixtor or similar to get anything higher than 24fps.
You could use my Davinci Resolve Lite Free 8.1.1 tutorial to get your footage colored.
And I agree with the OP but with a slightly less eloquent tone than the rather well written and informative essay - to me the current 2K 300fps quality is not at all Epic. That will most likely change in time since it is something that can through technology improvements alone. To me the new 3K / 8:1 setting was the missing key - 150fps looks beautiful on common sports, wildlife and natural action. The TIFF pull frames are crisp enough for People Magazine to print. I'm good for now
He's talking about Scarlet (it's even written in the url).
EDIT: Now THIS is seriously funny. You are the same guy who started bashing me when I asked why "Anonymous" thread was moved to "Shot On Red" forum (it was moved as you can see).
I will provide the quote one last time for everyone to see you self owning yourself:
Obviously your reading comprehension skills are lacking along with your methods of scientific analysis.
It wasn't moved. The original poster posted in this section erroneously / which by the way is titled Red Discussion - not shot on Red.
No wonder why you didn't see the "Scarlet" in the url LOL.
Should I say it once more? Okey here it's to remind you:
obviously your opinions have no value anymore when it comes to something that is compared with eyes.
Dan makes cool RED Instructional Vids. Josh makes pointless rants. I like Dan more than Josh
Whose rants are pointless? Dan rants for him not seeing things (like the case moved thread, scarlet url and so on) and for me providing realistic opinions that other high profile people like Bloom agrees with just because he doens't like reality but rather he likes to see (or not see as it's Dan after all, lol) everyone telling things as he would like them to be told.
Just to clarify:
We are in a subforum Called Epic - so any kind of _Speculative_ Article by Philip Bloom about Scarlet doesn't belong in here as a point of meaningful, factual, grounded in the Real World, hands-on, scientific or otherwise reference.
Secondly:
The other thread in which I called you out was originally in Red Discussion - then it apparently got moved to Shot on Red - then back to Red Discussion - then back to Shot on Red - where it eventually died.
I actually had enough conviction to be responding to your Hyperbolic, and ill-informed posts from my iphone, with which I responded about a Really great Third Party test done in Australia - which you then slagged, when I realized that the whole thread had been moved to "Shot On Red" - a place where it didn't belong since it wasn't shot on Red - it was shot on Alexa.
Once you have done some real world analysis of anything, please get back to us. Even if its just opening a 2kWS .R3d file in Redcine X and showing us how bad it is.
