Nick Shaw
ps:is your lut only applied as viewing Lut while grading , than baked IN at the end?
If you are viewing on a Rec.709 monitor, and delivering for Rec.709 display you bake in the LUT. Same for e.g. P3. If your grading monitor does not match the final viewing environment, then it gets more complex, as you need to build a LUT to emulate that while grading, which you do not bake in.
