Epic Issue
Next time: double check your tint settings by pressing the color temperature number on the LCD, keep it pressed and you get the secondary menu, where you can read out the tint setting and change it.
I am very annoyed by the tint myself, it´s so easy to accidentally press a button assigned "auto white balance" without even noticing it, and if you just change the color temperature back the tint is hidden and so easy to overlook.
it´s all meta data of course, but I think there should be NO auto white balance buttons, and those who wants them should assign them to user buttons. or at least there should be a "auto white balance in progress, continue?" screen.
+1 to all of this
Yeah, not sure how many of you missed the part where it said, "I did a full factory reset" so, just to reiterate,
1. I have just now done a full factory reset on the camera 5 times. Also have checked for look and all the profiles and its neutral.
2. Without doing anything else, I record something from where the camera is. I did not have side handle on in case the wind pushed the button auto WB button behind my back.
3. I take SSD and Put into RCXP and all clips have +19 Green tint. Same for RCX so i dont think its software problem.
And yes its not a huge problem for me as i would just profile it, but when people with no brains hire out the camera, i don't want phone calls at 3am asking why all the clips are green.
Can you try doing a reinstall with the "force_upgrade" procedure?
