What HDMI spec is EPIC OUTPUT?...want to use HDMI to COMPOSITE converter
Obin Olson
www.dv3productions.com
Hey so I am wanting to use an Epic with a vga set of video glasses that have composite IN....and I was looking at this:
http://www.ebay.com/itm/HDMI-Compos...ltDomain_0&hash=item3cbbf3ba62#ht_2726wt_1397
as you can see it's specs are:
HDMI Version
Compatible with HDMI 1.3 and HDCP
Input HDMI Resolution
480p (60Hz), 576P (50Hz), 720p (50Hz / 60Hz), 1080i (50Hz / 60Hz), 1080p (50Hz / 60Hz)
will this "see" the epic hdmi feed and give me what I need?
ALSO: Does Epic even FEED hdmi OUT while recording at this point?
I do wish they'd hurry up with the HDMI output.
I'd be willing to accept 8 bit 720p, or a simple option to turn off SDI so that HDMI can run, if that is a problem. Ultimately I really want both SDI and HDMI working as "advertised" but something as a stop gap is better than nothing I have right now.
That's keeping me on Red One, and other cheaper HDMI capable cameras, for a lot of jobs that can frankly use Epic.
Its a budget reducer I count on very often.
Decimator or other SDI to HDMI converters are items I have to expense, because they are nearly impossible to sell as rentals with the level of producer I deal with. (Yeah yeah ... FML)
I've got an AJA HDSDI downconverter....I guess i'm good :) thx guys
Epic
Epic
Also note that playback is not enabled at this time for EPIC M or X from the camera.
Either you have to record it on devices such as AJA KI pro or Mini through Hd-SDI output and then playback from there or offload the data to hard drive and playback from REDCINE X.
Harcharan
