- Thread starter
- #61
Jannard
Red Leader
- Dec 28, 2006
Build 487:
http://red.cachefly.net/redcinex/test/REDCINE-X_build_487_mac64.zip
http://red.cachefly.net/redcinex/test/REDCINE-X_build_487_mac32.zip
http://red.cachefly.net/redcinex/test/REDCINE-X_build_487_win64.zip
http://red.cachefly.net/redcinex/test/REDCINE-X_build_487_win32.zip
Changes since 478:
Magic Motion HDR blend option added.
BWF audio export added. Camera audio only.
Fix for REDline --outDir option for directory structures.
Fix for crash when going in and out of fullscreen mode.
Framing flip (horz/vert) + offset plus + export fix.
Base names of R3D files shown in the bin/browser.
Miscellaneous crop fixes.
Fixes letterboxing for exports with odd height image data.
Attempting to scale to sizes > 4096 with rocket uses software scalar instead of giving decode errors.
Fix for mouse detection on crop box in Viewer when switching between active eyes in 3D mode.
FCP XML can now be included with Quicktime timeline exports.
Fix for crash for video slate button is pressed when no clip is in the viewer.
Fix for Windows where unicode filenames are properly opened from the command line.
Fix so that Quicktime export errors are all correctly reported in the export details column.
Fix so that video out button is properly disabled if no rockets are available.
Updated various resolution combo boxes with new Epic resolutions.
Tangent Wave CP300 is now enabled on Windows.
Update so Avid ALE file on export uses updated clip look metadata.
Fix for max open file handle limitation on MacOSX which could cause exports to fail.
Fix for properly creating a unique subfolder on export when enabled in the export preset.
Fix memory leak with various message boxes.
EDL import can now use per clip framerate.
Multiple R3D source directories are now supported for EDL/XML import.
Fix so that metadata export now correctly matches that of REDLine's.
Avid ALE files can now be imported.
Fix so that framing tool is properly updated when enabling lock aspect ratio.
Double clicking on a finished export now opens the file if possible.
Relink tool now supports auto linking via search directories.
Fix for crash when the white balance tool is used and no clip is in the viewer.
Jim
Changes since 478:
Jim
